Discuss who connects the thermostat in the Australia area at ElectriciansForums.net
L
leeweimaraner
can you please give me some advice electrician has run a 3 core and earth from boiler to room stat honeywell 2360b who connects the stat and who connects to the boiler ??
Depends whos Part P regestered as this work is notifiable , realistically its the responcability of the electrician not the plumber and as IQ has said
is a electrician alowed to make connections in a gas boiler(removing covers)?
i see no problem with this. connecting the stat in the boiler does not interfere with the gas side of it.
Exactly, 'don't disturb the gas route' is the advice we received from Gas Safe.
We get a fair bit of work from a plumber who basically rings us as soon as he suspects an electrical problem with the heating system (about 80% of the time!).
Reply to who connects the thermostat in the Australia area at ElectriciansForums.net
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
