AJB Temple
- Reaction score
- 89
I need to fit compressible rubber or neoprene gaskets between 12 Hager 2 gang stainless steel flat sockets. The gaskets are needed because the wall has small marble mosaic tiles that have slight unevenness and grout indentations and I would like to minimise risk of water ingress. Must look professional - not a bodge.
I've looked online but can't find anything suitable apart from very expensive Hoyles ones that are £4 each. The sockets do not need spacing out, so things like 7mm or 10mm spacer rings are no use.
I only need them at about 1 or 2mm thick (absolute maximum 4mm). Standard double socket size, ideally with screw holes locators. If necessary I will have to buy some rubber and make them, but if anyone can suggest where I can buy them I would be grateful.
