- Reaction score
- 0
I have a Samlex 600 Watt PSW AC inverter. The inverter connects to the battery source by way of the positive and negative clamps from the back of the inverter. I have isolated it away from all connections. It is connected to the 12 volt battery only. It beeps.
Presently, the battery voltage charge is reading 12.2 volts, but even when it is reading 13 volts the inverter beeps still. I have swapped it out with a new inverter, the beeping persists. The green indicator light at best flickers faintly and at worse it's out completely.
I tested the inverter by connecting two load sources to the AC plugs on the inverter including a lamp and a hair blower. There is not the faintest sign of power to these devices. Any suggestions?
Thanks in advance,
Gil T
Thanks in advance,
Gil T
