Discuss Why is there no power to my Dyno-Glo Garage Heater? in the DIY Electrical Advice area at ElectriciansForums.net
Long Con
Hi, I have a new Dyno-Glo Garage Heater that I connected to the breaker, and it won't turn on. Multimeter reads 120V going at each node in the heater.
Breaker is a double-pole 30 Amp Stab-Lok, rated for 240V.
I'm not sure how to troubleshoot further, and I'm hoping for some direction, please.
Hi, I have a new Dyna-Glo Garage Heater that I connected to the breaker, and it won't turn on. Multimeter reads 120V going at each node in the heater.
Update: the heater works on a 30-amp double pole Siemens breaker, but not on the Stab-Lok. I could really use some advice.
Reply to Why is there no power to my Dyno-Glo Garage Heater? in the DIY Electrical Advice area at ElectriciansForums.net
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Hi everyone. The title should sound crazy enough, but it's what happening in my 72-years old home we've purchased 2 years ago. I found the crazy...
I'm installing a Rheem Retex-27 27kw electric water heater. While it's not required by the code where I am, I'd like to have a disconnect switch...
