Discuss Wifi controlled FCU suggestions in the UK Electrical Forum area at ElectriciansForums.net
peterhyper
A customer has a couple of storage heaters on an economy meter and wants to be able to control both (seperate timer FCUs for each heater). They ideally want wifi controlled FCUs, but there isn't much on the market and the reviews aren't great (I usually use timeguard standard timer FCUs).
Any suggestions because I don't want to keep getting phone calls that they can't connect with the wifi FCUs etc?
If the supplies are on economy 7 then they will switch off anyway outside of off peak period.
Fused spurs may also not be ideal dependant on the size of heater e.g. running a fuse near it's limit for long periods.
As they are radials, using basic wifi relays in conjunction with contactors at the front end may be a better option. You could use unrestricted supply for control circuit, switching the off peak circuits through the contactors. Then there would be no chance of them running outside of the off peak times.
Seems a lot of effort for little gain though.
Thanks for the info. The heaters are already on FCUs, but I'm replacing the consumer units and the customer wants the heaters taken off the economy 7 meter and to have them on timers so they can have them on during the day when they want (no central heating in the property).
Thanks again
Reply to Wifi controlled FCU suggestions in the UK Electrical Forum area at ElectriciansForums.net
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Hi, Have normal fused immersion heater switch. I would like to add a smart wifi switch to it so when my Solar is producing over 3k spare, going...
Our old Friedland chime all too often now emits a only faint "ding"- because the person at the door (usually a delivery driver) just "dabs" at...
I'm repurposing an agricultural building as a research workshop, where sometimes reasonably accurate air temperature control will be needed. I...
Hi I posted a few weeks back what looks like to be an economy seven timer located in a store cupboard in my flat that I assume was connected to a...
