Discuss Will an rcd operate in the UK Electrical Forum area at ElectriciansForums.net
If it’s 400v input 110v to earth output?All depends on what sort of transformer it is.
Isolating?
Auto (neutral carried through to secondary)?
Is the earth connected to the secondary center tap?
That is not answering the issue of isolation!If it’s 400v input 110v to earth output?
No it’s not an isolating transformerThat is not answering the issue of isolation!
Can you draw a diagram of the arrangement and post it?
I am unsure if you are asking
A rcd feeding primary side, will a fault on secondary fed circuit trip it.
B if you have an rcd on the primary supply, will a second rcd on secondary output still work.
OK, so try answering a few questions first to see if you can deduce the answers:
1) Is the transformer you sketched isolating on not?
2) What path for current in a RCD trips it?
3) To answer question (a) is your answer to #2 normally present in this arrangement?
4) Your question (b) has several aspects:
- What is your definition of "not work"?
- How might two RCD in series fail to meet the IET regulation 536.4.1.4?
- Returning to your answer to #2, is that present in your diagram for the secondary circuit?
Reply to Will an rcd operate in the UK Electrical Forum area at ElectriciansForums.net
