Discuss Will flat plate double socket and spur switch fit in dual box?? in the UK Electrical Forum area at ElectriciansForums.net
E
egginyourface
Evening all,
Ive first fixed a double back box and single box together with one of those box spacer things.
Someone told me that the problem with these things is that socket and spur switch will not fit together if they are the flat type as they are wider. I this true?
I think it depends on the manufacturer what size they make the flat plate, although they are better than the normal brass fittings.
Check on the size of the plates you are intending to fit, if they match normal PVC accessories OK, if not then you may well have a problem.
This thread covers a similar situation with brass fittings!
Reply to Will flat plate double socket and spur switch fit in dual box?? in the UK Electrical Forum area at ElectriciansForums.net
Good evening. Currently sorting out my girlfriend’s flat for rent. I’ve found all sorts of bad electrical work. Can anyone advise if this is an...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
