Discuss Will this work? (For connecting 50 amp RV outlet to dryer) in the Electrical Appliances Forum area at ElectriciansForums.net
wrybread
I'm a DIY'er helping a friend connect a 220v dryer to a 50 amp RV outlet.
The dryer has a Nema 10-30R plug and is in a shed about 4 feet from the 50 amp outlet.
I'm thinking about getting this cord to plug into the 50 amp outlet:
And connect that to this 30 amp outlet:
And put that in a double gang box inside the shed:
And plug the dryer into that.
Thoughts?
And the 50amp cord has 4 wires, how do I connect those to the 30 amp plug, which has 3 connectors?
Thanks for any help.
View attachment 103251 View attachment 103252
Thoughts?
We’ll you need to change the 3 wire plug to a 4 wire. If it’s the actual cord and plug you can buy 4 wire at Lowes or Home Depot. If it is the receptacle then change it out to a 4 wire receptacle. The extra wire is the equipment ground missing.
Thank you. But wouldn't a 4 wire receptacle not accept a Nema 10-30 dryer plug? I'm trying to avoid using an adaptor if possible.
The Nema 10-30R plug does not have an earth, and I understood it's not supposed to be fitted to appliances any more. It's presumably an old dryer? Surely the best course of action is to change the plug (including presumably the cable, as per Megawatt) on the dryer, unless you still want to be able to plug it into an old Nema 10-30 socket somewhere? (in which case that could/should be changed as well!)
Reply to Will this work? (For connecting 50 amp RV outlet to dryer) in the Electrical Appliances Forum area at ElectriciansForums.net
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
I currently have a 100 amp sub panel for a 50 amp RV hookup (on a 60 amp breaker). This is about 100ft from the main with 2/4 wiring. Would a...
Bought a range from Home Depot. They supplied a 40 amp cord. Electrician was going to use a 50 amp outlet. Here is the oven and cord...
Hi all, I live in a townhome in Northern Virginia built in the mid 80's. I currently have a 30A double pole breaker feeding 220v to my laundry...
6K
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
