Discuss Wind turbine in the Commercial Electrical Advice area at ElectriciansForums.net
Hello Peeps,
Advice please.
A customer has a 10kw wind turbine, this is configured as split phase.
He's had to install 3 phase but the company that put the turbine in only installed a 3 core swa to the turbine, whoops.
This normally would be ok but the control gear requires a neutral.
The plan was to install a single core swa and put it in the same trench as the existing swa.
Spoke with the niceic and they say its a complete no.
Can any of you guys see why this is this case?
regards
Paul
ps hope i have made sense.
Hello Peeps,
Advice please.
regards
Paul
What reason did the NICEIC give? if it was up to me I would get the dipsticks who installed the turbine and the cable back to do it right at their expense, or was a 3 core specified at the outset.
to be truthful i am not sure who specified 3 core?
The niceic have quoted parallel conductors from the regs but i cant see anything in there about this.. My mate has been dealing with them and i haven't spoke with him propley about this, just got a text off him.
I personally cant see a problem so long as there in the same trench.
All hv cables are singles.
No they aren't
Maybe they are using 521.8
Each part of a circuit shall be arranged such that the conductors are not distributed over different multi core cables
What about installing a isolating transformer and make your own neutral
Reply to Wind turbine in the Commercial Electrical Advice area at ElectriciansForums.net
Hello everyone, I'm currently working on a project to upgrade an existing renewable energy system and could really use some expert advice. The...
Been looking at a CU change in a small office and would appreciate comments on the following. Office is supplied from the mains intake in the...
6K
Hello, I'm not an electrician. I'm looking for advice on the capacity of an existing SWA cable I have on a farm. It's a three phase cable...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
Hello everyone my name is Tarek, i work as a concert and show lighting operator with over 20 years of experience in this field, so i have gained...
