Discuss Wind turbines in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Do you expect FiT payments?
If so the only sensible options are the Gaia 11kW or the Bergey 10kW. But you need a suitable site to match. Below this size wind is frankly not worth the hassle unless you need/wish to be off-grid.
About the right price for the Kingspan 6kW fully installed. But it would be more cost effective to go for a single Gaia 11kW if he has 3 phase already on-site and can get planning permission for it.
Reply to Wind turbines in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello everyone, I'm currently working on a project to upgrade an existing renewable energy system and could really use some expert advice. The...
I have an old sunnyboy 1700 and I'm trying to connect it to a 1kw wind turbine. I've been told that if I can get into the inverter software to...
And now for something completely different! I have been after a power station telegraph for decades and due to the fact most would have been...
Hello, I need to understand whether a DC motor is sturdy or not. The support person told me to measure the armature and field winding resistance...
I want to check the insulation of the 3-phase 400VAC asynchronous squirrel cage motor. Motor's stator windings are connected in delta. I've read...
