Discuss Wire a double oven in the DIY Electrical Advice area at ElectriciansForums.net
Hi am replacing my double oven. And was wondering what wires go where in the connection on the oven see attached photos.
Much appreciated in advance for your help
  • Wire a double oven IMG_20190713_175719_1 - EletriciansForums.net
What do the manufacturers instructions say?
So does it work? I'd be testing it before fitting it just in case.
If you know the make and model you should be able to Google and download the manufacturers installation instructions.
Bought new or second hand. If new it should have instructions.
If second hand whoever is giving the guarantee should supply the instructions.
i'm sure a member is close enough to you to connect that up, ensure circuit and connection cable are correctly sized... for a small fee, of course.
West Lancashire, isn’t that the Emerald Isle? ;)
Reply to Wire a double oven in the DIY Electrical Advice area at ElectriciansForums.net
