Discuss Wire and hot pipes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
might not be the sparks' fault. wet-head may have been after.
Very true, I should have said the tradesman responsible should come back to sort it out. Insulation is a viable option but why bodge someone else's work to make things right?
If your worried about cables becomeing slack and eventualy resting ontop of hot pipes put a wooden noggin inbetween the cables and pipes the full width of the gap between the joists....that way the cables will sit ontop of it,could even clip the cables to the noggin.
Does it look as good as this?
And who came first. Sparky or electrician:eek:mg_smile:
I've seen far worse than that. Few years ago, rewired my grandmas house and found the T&E in the same holes as the copper hot water pipes, actually touching and in places wrapped around them. Surprisingly, I didn't find any issues with the old cables before I relocated and replaced them.
Reply to Wire and hot pipes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Electrician has done rewire, plumber with not much space has some central heating and hot water pipes touching in some places. See images...
I'm in Raleigh, North Carolina and have a well for my house's water supply. For some reason, pitless adapters, which allow all piping to be run...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
