Discuss Wire question - h07z-types cables. BS EN 50525-3-41 6491B. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
zoltan
Hi there,
I'm trying to find an answer from the web but I have just got more confused.
I've got lots of h07z-types cables. BS EN 50525-3-41 6491B.
Can it be used for power circuit?
More specifically, I would like to install a socket in my garage to use an electric heater.
The info I've found on current rating states 17A. Which should be okay if I'm using with a 16A breaker. But I don't know if it's allowed here.
And I don't want to burn my house. Some other websites says this type of cable is for lightning.
Can you give me any advice please?
I have just checked and the cable you describe is a single core, correct? how are you intending to wire the heater in your Garage? is the Garage adjoining your house, or is it a stand alone Garage?
Thanks for the reply.
It's multi core cable (7) 1.5mm. it's a stand alone garage (more like a man cave). The heater is 2kw electric one plugged into the socket. This would be the only thing in the circuit.
The best advice I can give you Zoltan is to get an Electrician to run you a supply to your Garage properly in conjunction with BS7671 Wiring Regulations, your method is a dangerous one, the cable is to small for starters. That's the best advice I can offer
Thanks for the advice.
That is not multi core cable, it is single core stranded conductor as far as an electrician is concerned.
It is commonly referred to as singles, it can only be used inside a suitable containment system, such as conduit and trunking, it cannot be used on its own in normal circumstances
Also, without being funny, what's a bit of suitable cable cost? Probably next to nothing. Are we honestly trying to save a few pennies here?
Reply to Wire question - h07z-types cables. BS EN 50525-3-41 6491B. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
Hi, I’m new to the forum and am seeking some advice please. I’ve picked up a job that another electrician has abandoned, the job is to...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
