Discuss wire single socket off garage feed in kitchen in the UK Electrical Forum area at ElectriciansForums.net
Hi there,
in my kitchen (well dining room but its open plan, may have part p implications) where i want to put my tumble dryer there is a blanking/access plate (single) which contains a 2.5 te cable connected to the amoured cable via a block which feeds the garage breaker radial circuit and lights.
This 2.5 te cable is fed from the cu on a 16 breaker and the cu is a dual rcd unit (new build house 2015).
my question is can i change the blanking plate for a single socket and feed the tumble dryer from this socket?
i know dryers can be hungry so whats the implications of this?
and if i can do it, can i do it myself? its just connecting a faceplate but unsure if this falls under part p or not?
Sounds a mess, T&E connecting into SWA and then your going to attatch a socket into the block.
Best bet is to call someone out mate, I would leave that circuit for the garage alone. Its on a 16A mcb so the tumble dryer would be using a large chunk of that.... so your garage becomes next to useless whilst your drying clothes.
Agree with other posts that the SWA sounds like a bit of a hash in all honesty, not surprised as i see the house was built in 2015, so many new builds are put up in quick time and the quality of workmanship is often awful. People look at the cosmetic things when buying a new house but what is under the floor or in the wall is often barely compliant.
The others are talking rubbish. Nothing wrong at all with a 2.5mm radial in T/E joined to a properly terminated SWA in a flush metal box. There is no reason why you cant change the blank plate for a single socket and terminate both conductors in the socket. You can do that yourself if you are competent to do so,and the load in the garage along with the dryer will not exceed 16a. However it will require testing in accordance with the regulations which is likely beyond your capability. Potentially it would be worthwhile increasing the mcb to 20a. It would then be a 20a radial, a standard circuit, but that must be carried out by a qualified electrician. Probably an hour to an hour and a half labour to fit the socket,test and change the mcb to a 20a along with a cert. Money well spent so you know it's safe and compliant.
Depends on what he's using in the garage. The tumble dryer is taking a fair amount of current already.
Reply to wire single socket off garage feed in kitchen in the UK Electrical Forum area at ElectriciansForums.net
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
