Discuss wireing in a loft in the Australia area at ElectriciansForums.net
E
Edd
Having to deal with a complaint, that a tennents house has recently been rewired and their not happy with the cables in the loft just laying under the insulation. now im sure when any of us do a rewire only sometimes do we clip them, but this persons saying they should be protected by conduit or drilled through the joists!!
any input would be greatfull as Ive gota reply to a stinking email
thanks
Edd
drilled through the joists would mean they are <50mm from ceiling and the joists are weakened. why conduit? do they have rats?
New cables just laying under the insulation is poor......normal practice is to clip to the sides of the joists,preferably out of insulation. Even better is to use running boards clear of insulation.....I'd complain if my newly rewired loft had the cables laying under the insulation unsecured.
just spoke to the chap who rewired it and theres 200mm of insulation across all the joists and his pushed all the cables along the edges as know joists can even be seen under all the ichy wool
last loft i saw insulated had warning signs " DO NOT WALK IN LOFT- DANGER OF DEATH" and other silliness. i agree the cables should have a degree of clipping and be routed away from the centre of the loft where they cross the joists and clipped to the sides where they parallel the joists. get in there with a box of clips and a manchester screwdriver. couple of hours of sweating should do it.
Wow the householder must be bored...if it was a choice between drilling joists and putting cables neatly to the side I know which one i'd choose. Its a judgement call for the installer IMO, I'm not talking about throwing cables over joists but when there are things in the loft, itchy insulation and its about 100 deg and you can hardly move to begin with I think its acceptable not to clip.
I'm sure if you had added the labour cost to remove all the insulation so you can fix to the joist then put it back again he would have told you where to go. Most lofts I see now that have had the extra layer of insulation added, the added layer runs across the original layer, that makes it even harder to work around.
How were the cables fixed before the rewire?
on all our rewires mainly council rewires we always run over insulstion on running boards and where needed to spout off we use all round band
were needed we run cables in eves
this is mainly due to spec council want
when up in loft wiring it it only takes a little longer to do job tight and once
as for heat/insulation/stuff shoved in loft thats a poor excuse to be honest
thanks for the input, as far as i know it was originlly wired with cables just pushed into the edges,, no clips,, so the sparks has just done like for like.. I understand in an ideal world we would clip them to the edges of joists and I have done just that on new builds. but as others have said, when you cant see the joists and its 100 deg + up there you aint gona spend half the day doing it... can anyone point me to a regulation that can back the sparks up on this? or am i gona be asking him to go back with conduit and re do the lighting circuit!!! thanks again..
PS.. I had read somewhere that a loft is not to be used for storage but is an area to allow a pitched roof for rain to run off. i see the skilled persons only reg here!! i say padlock his loft and tell him its not for storage, and his not allowed up there....
Re: wiring in a loft
The On-Site Guide (17th Amd 1), P127, ...examples of method of support for cables... : "5 For sheathed and/or armoured cables in horizontal runs which are inaccessible and unlikely to be disturbed, resting without fixing on part of a building , the surface of that part being reasonably smooth."
So I would have no problem with twin & earth lying on the plasterboard ceiling and covered with insulation provided that the current carrying capacity of the cable, taking into account the insulation, is OK. I would also make sure that the cables were off the top of the joists in the immediate area of the loft hatch and any other obvious maintenance routes, eg to water tanks, valves, shower pumps, etc.
As handysparks has said there's no requirement for clipping in BS7671. Being a loft I would say there is also no requirement for excessive neatness. Personally I am rarly seen going into a loft with cable clips. I do all my joist jumping right at the edge of the eaves or down the central purlin so that the loft can be boarded without obstruction.
The tenant is a busybody, they obviously just enjoy having something to complain about.
I cant believe the excuses being found on this thread for a poor job.....lofts shouldnt be used for storage?...there isnt one in the country that isnt full of junk.
Cables in accessible roof voids unsecured and run in a way liable to result in mechanical damage is poor practice regarless of 'regs'. It doesnt take much longer to do it right. Personally I always look in the loft in order to judge a job,if the visible wiring in the loft is cr#p the rest of the job probably is as well.
so you would roll off all the insulation from the joists to find them, then clip along each and every one then reinsulate the loft! nothing like laying stretched out with your face and belly laying in insulation trying to get a clip in! ile stick with clipping where needed and pushing into the eves.
It's what we have to do 5 times a week
we have two in loft
do it once do it right
Yep have to say.
It's not pleasant rolling back 30,40,50 year old loft insulation. I hate it.
But I always do it and clip cables to joists wherever possible.
Exception was last week on a bathroom fan install where the loft was filthy, damp, and very very low angle on roof, so no head clearance.
I did advise the client how and why it was done that way. Plus I left enough slack in the cable for it to be tidied up later.
I always work on the premise that nothing stays out of sight forever. For all I know the client may renew the loft insulation the week after I complete the work and be up there working around my cables...
Nothing wrong with cables tight to the edges of the loft...out of harms way. But most of the points wont be at the edge and will need to get across somehow.
Either pull back the insulation and clip to the sides of the joist....or use running boards above the insulation. Either way,there's no excuse for throwing cables across the top because you cant be bothered.What else cant you be bothered to do right?
Reply to wireing in a loft in the Australia area at ElectriciansForums.net
hello, i am just about to completely rewire a refurbished house. i have done the same to several houses in the distant past. i have just read...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
Hi all, Have a relatively simple question. Doing a rewire to make a circuit in a single room. My father is a retired spark, so no worries about a...
Hello, I'm about to start a complete house refurbishment, including rewiring and insulating between floors. As I understand it building regs...
NICEIC Certification Scheme NICEIC renewal assessment debacle!
Hi All, I recently had my NICEIC renewal assessment. We are a two man band. We only carry out small local work and we are approved contractors &...
6K
