Discuss Wireless Thermostat in the Australia area at ElectriciansForums.net
SSE
Got a new one today, and the boiler ain't firing up now. Got power at the receiver as the light is one but doesn't seem to anything going out, even when I press the manual over-ride. Not got a multimeter on me so can't check for voltage going out. Maybe faulty receiver. Anything else it could be?
link the terminals on the boiler that the stat. links. if it fires up then you got a faulty unit
Reply to Wireless Thermostat in the Australia area at ElectriciansForums.net
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Afternoon all, I have an issue with the loft socket. When we moved the previous owners had a 2.5mm cable going up from the CU Via FCU however...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
