Discuss Wiring a 4 prong dryer outlet and the 10/3 has no ground wire in the Electrical Appliances Forum area at ElectriciansForums.net
jwrunner
I have an older house that has 10/3 run to a box at the dryer location and I would like to put in a 4 prong outlet. My problem is that the 10/3 does not have a ground wire. Only Black (hot), Red (hot), and White (neutral). Can i use the existing wires and just add a ground wire grounded to the water pipes? Thanks.
John
John
Or would it be better to use a 3 prong outlet with no ground?
not conversant with US regs./code, but i'd be inclined to run in a new cable 2 hots, N, and ground. do it once, do it right. in the UK it is against regulations to use utility pipes as earth/ground.
John
John I hate to tell you this but once you start working on a dryer you have to install a 4 wire cable to bring it up to today’s standers. Good luck with your project
Reply to Wiring a 4 prong dryer outlet and the 10/3 has no ground wire in the Electrical Appliances Forum area at ElectriciansForums.net
I built a prototype Dog Dryer. Took a dryer element and pushed it into a vent pipe. Cut out vent pipe to access the two spade connectors on the...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
I have a 3 prong 240v outlet for a dryer that reads 240v across both legs and 120 across the ground. When I turn the dryer on and have the multi...
Recently moved into a house from the 70s. There's no ceiling light in the living room. Assuming the switch for the room was to one of the outlets...
