Discuss wiring a digital LED display to a project in the Auto Electrician Forum area at ElectriciansForums.net
M
mollydog
It's not car related but is a 12vdc porject, so hope someone can be of help to me on this project
I’m a bit of an amateur photographer when it comes to time-lapse photography and this past summer I’ve been doing some time lapse with my SJ4000, to do this.
up to now I’ve been using a small tripod and this timer:
to give me these kind of results:
https://youtu.be/uve5d4nBmyw
https://youtu.be/ryp4y8QgJdU
(can’t help the music, youtube takes out anything copyright)
I’ve now got the bug and want to use my DSLR and to add more movement to the time-lapse photography I’ve bought myself this slider rail:
to make the most of these sliders a motor is very desirable, I didn’t buy one that had a motor pre fitted as these tend to be out of my budget costing well over £300
and reading on the net that adding a motor to one of these sliders can be done and cost can be kept to around £50
from the many videos and tutorials on the net, I’ve managed to get a list of the parts I need and the wiring diagram, so I’m fine (I think) on that score, this is the diagram of my wiring and main parts:
but I would like to add a LED readout when I use the motor speed regulator, so I can repeat the speed settings of the motor, something like this LED readout
here is where I’m lost, I don’t know which one to get or where to wire it in (if this can be done)
to give you some idea how it will all end up, here are some photos from the net
in this photo the power pack isn’t shown but gives an idea of the package
eventually I’ll incorporate these micro switches at the ends to cut off power to the motor so I don’t have to keep an eye on the slider all the time
main spec of the electrical parts if it helps are:
MOTOR:
12V DC
Amp draw: 200 - 600mA
30RPM
Diameter: 37mm
Length (excluding shaft): 49mm
Shaft length: 21mm
Total length: 70mm
Shaft diameter: 6mm
Weight: 144g
MOTOR SPEED REGULATOR
Input supply voltage: 6V-30VDC(max)
PWM frequency: 16kHz; Duty Cycle adjustable: 0%-100%
Item size: 2.9*1.85*1.1 inches ; Net weight: 2.54 ounces
The maximum output power: 200W; Power-On LED indicator;
The maximum continuous output current :6A; Peak current is 10A
Features:
CCM6N DC Motor Speed Regulator controls the speed of a DC motor by adjusting Pulse-Width-Modulated (PWM).
Control the forward or reverse direction and the stop of DC motor by switch.
Incorporate a high power MOSFET and a high quality potentiometer.
Adjustable speed range is 0%-100% (both Positive and Negative DC output).
Suitable for the DC motor (or DC load) within 6A.
POWER PACK
Talentcell Rechargeable 6000mAh Li-Ion Battery Pack For LED Strip And CCTV Camera,12V DC Portable Lithium Ion Battery Bank
12V DC.
6000 mAh High Capacity, 12.6V 1A Charger.
Compatible with any LED strip light products,CCTV Camera,LED Panel.
Rechargeable Lithium Ion Battery.
Wall plug charger and cable are included.
any help on what LED readout and how/where to wire it in will be most welcome
many thanks
hi,
1. led display will need to have a controller of some sort.
motor is PWM driven, means a simple volt-meter wont pick up the voltage correctly.
it wont work directly with your current setup.
2. those micro-switches may not be able to handle current taken by the motor...
3. you may get an arduino/PIC type device, hook it up to the the microswitches, motor and display and let it control whole lot.
its around £30 in parts if you can do it yourself... needs a bit of soldering and some programming to make it do what you need.
not sure if there is an off the shelf solution for that, never seen one.
you can pm me if you get stuck, can make some one-off project if required...
Thank you amlu, doing some research on the net, I also came to the same completion that using an arduino is the best way as then the motor can be programmed and also get the motor to stop, get the camera to take a long exposure (like those night shots of the stars) then have the motor move a set distance before getting the camera to take another exposure (I've not yet bought any parts for making the motor and controller , so can go the Arundio route)
on one of the links, it mentions to use "Arudino Uno, for best results pick Rev.3"
I will send you a privat message later, (I'd be cery surprised if there was an off the shelf solution for this)but have seen the parts needed , just my electronics limitation stops me :)
here are a few links that explains, what others have done, using Arduino
this first link looks very informative, some links do show how to build a slider, but as I've got that diregard all of that, just the Arduino, on the first link it also shows the code needed to make the Arduino to work with the slider
many thanks
Motion Control With Arduino: Motorising a Camera Slider - Envato Tuts+ Computer Skills Tutorial
http://www.buildlog.net/blog/2013/10/camera-slider-controller-shield/
http://clickglide.com/?p=822
OpenMoco based timelapse dolly - first prototype | Elysia Productions - Andre Crone
DIY motorized camera slider « ClickGlide
Reply to wiring a digital LED display to a project in the Auto Electrician Forum area at ElectriciansForums.net
hello guys i have a (3-6v dc motor), (DC Motor PWM Speed Controller 3V 6V 12V 24V 35V), (3.7v 1200mah rechargeable battery) and a (Charging /...
Hi, First of all I must explain why my posting came to be on this site, I was looking on the internet for a forum that could help with a project...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
Hoping someone can help with this small little project. I reload ammo and I want to make what is known as a "vibrating powder trickler"...
Hi all New to the forum and wanted to some advice for a project, although I’m not an electrician I’d consider myself able to do some handy work...
