Discuss Wiring A Dimmer Switch in the Industrial Electricians' Talk area at ElectriciansForums.net
W
willbones
Hi guys, hope someone on here can help me out with this problem. I've got in from work tonight and the Mrs has unwired the dimmer switch.
Here is a link to a diagram of what im faced with
index
This is how i think it needs to be re-wired. Am I correct? Also, does black or red go in L1 or L2?
Thanks in advance
Hi, your picture doesnt work matey, But you may well have 3 wires, 2 black and 1 red. So put the black wires in L1 and L2 and the red in the other. The picture would be very helpful, cheers
Picture seems to work on mine, just click where it says index
index
i've taken the www off this one, so copy and paste into address bar should work, rather than clicking
I can't see the picture either but I'm intrigued what possessed your missus to dismantle the dimmer whilst you were out?
tried it . says site no longer available.
bugger this thread is 4 years old!!!!!!!
doubt it, wonder what else shes started to take apart? maybe shes a hands on women and he works in the office if ya no what i mean.
Reply to Wiring A Dimmer Switch in the Industrial Electricians' Talk area at ElectriciansForums.net
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
I have a led panel that i want to dim. It is dimmable but without a dimmable driver. I have a dimmer module and a dimmer switch as shown in the...
Trying to install a Lutron Toggle/Dimmer (TGCL-153PR) Confused, as the current switch has 3 wires gong to it Black, White, and Red (there is also...
Hi. In the images. One is a 2 gang dimmer switch and the other a normal 2 gang switch arrangement. Dimmer 1 controls the main ceiling rose and...
