Discuss Wiring advice for outdoor supply in the UK Electrical Forum area at ElectriciansForums.net
We have a thick cable leading to the pond area in the garden. It has a breaker at the house end. When we moved in it had a standard household socket box on the garden end.
After redoing the pond I decided to put a weatherproof junction box on the garden end of the cable to wire my pond pump and UV filter to.
The cable is really heavy duty, the live and neutral have about 6 thick rigid wires in each, and the earth's wrap around the outside of each wire.
My box only has fairly small holes for connecting cables - like you would have on a normal household plug.
As I'm not able to get all of the wires into the connections I'm not sure what to do. Would it be ok to cut a few strands off to get them in? I think i could get 3 or 4 of the thick strands connected for each. There wouldnt be that much power drawn by the pump...Otherwise what are my options? I don't want to run a whole new cable from the house.
a photo would help. you could terminate the thick cable into a IP rated adaptable box, then run a smaller cable to the socket. would like to know what size breaker is at the house end.
thanks, maybe these will help?
From what I can tell by the pics, the first pic is just the RCD for the cable going outside. What is the RCD wired to? A bigger pic showing more of the wiring and consumer unit may help.
Also the 'weatherproof junction box' is only rated for 5A. Is that enough for your pond pump and UV filter or is that just the fuse rating for one of the outputs?
When you say the earths wrap around each wire - do you mean there are earth strands around each core? Or is it one lot of steel strands around all of the cores? Can't tell if that's standard SWA (steel wire armoured) cable from that photo.
I think you are right to get a sparky in yes. And that cable does not look like the correct type.
Let us know what he says if you don't mind.
Reply to Wiring advice for outdoor supply in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
