Discuss Wiring cooker hood to a cooker switch! in the DIY Electrical Advice area at ElectriciansForums.net
gijno
Hi, I have one of those cooker switches which has a single socket built into it. The cooker switch itself should has a 45a fuse at the consumer unit. Picture below
I want to fit a new cooker hood/extractor. The old one I've always used it by plug it into the socket. The problem
with that is that it looks ugly and even if i chase the flex into the wall I would have to bring it out again before reaching the plug.
What I want to know is... can I just join the cooker hood cable with the cooker cable?
Is it any chance of it being dangerous to have a cooker hood cable joint with a cooker circuit?
Thanks in advance.
Don't connect the hood to the cooker switch. End of.
popcorn at the ready
Cooker hoods typically require fusing down to 3A - check the manufacturers instructions. With a plug, it will (hopefully) have a 3A fuse fitted. Alternatively you can connect it to a fused connection unit, again with the correct size of fuse.
and fed from a local socket circuit, not from the cooker point.
It does exist a socket which has the cooker switch and one switch with fuse where to attach cooker hood cable?
Oh dear oh dear. I really would get an electrician in. Daz
Reply to Wiring cooker hood to a cooker switch! in the DIY Electrical Advice area at ElectriciansForums.net
Hi I have a switched fuse spur where the cooker hood should plug in to… above the actual cooker. I was wondering if I could swap this out for a...
  • Locked
Hi I also posted this on the DIY Electrical Advice - Electrical Appliances Forum My Kitchen has never had a cooker hood installed. Where the new...
Cooker circuit has B40 MCB in the CU for the cooker, confirmed wired to the cooker outlet throughout, via a cooker switch & socket with a 10mm...
(Trying again, as picture didn't post first time) Hi, I'd be very grateful if anyone could help me here. Below, I've pasted a sketch showing how...
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
