Discuss Wiring down under in the UK Electrical Forum area at ElectriciansForums.net
sparks1234
I did have a little chuckle when I was in New Zealand and managed to find this in my hotel room, shut the door quick on it though
I see your concern...loads of dust and cobwebs, and the hinges are squint
Slotted screws don't line up in the hinges, neither do the bare brass ones in the Top and Bottom row Ceramic fuse carriers.
Labels are all over the place.
Some of the Fuse holders are upside down.
I would say not quite that old. PDL didn't start up until 1937 and the use of micro-break main switches really started in the late 40s / early 50s
Was the hand-wired, hinged panel format widespread in NZ? We never used it here, but it was popular in various parts of Europe.
Looks about normal.
My brother in law lives out there, and when we visited I couldn’t resist having a look.
Wired in singles behind that hinged plate.
Like an industrial control panel door but much less neat.
Board was outside so if you were unlucky enough to need to access it, it would be dark and raining.
Interesting accessories as well. Same size back box for everything. Switches or sockets, just mounted different. Horizontal or vertical.
The plug pins were at 45degrees to the flex of the appliance, so it didn’t matter if a socket was vertical or horizontal, or if a 2 gang socket was mounted one above the other, or side by side.
Reply to Wiring down under in the UK Electrical Forum area at ElectriciansForums.net
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
I have a main panel beside my meter on the house built in 1987. Then a 4 wire feed into a 200 amp panel on an inside wall of my basement. All of...
Hello, Behind a tiny door in our under stairs cupboard we’d like to build a miniature room in which a little light would come on when the door...
Hi all hope u all have a fab christmas , my name is Nick and i bought a roller garage door it got delivered yesterday but due to holidays the...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
