SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Discuss wiring fire alarms in the Industrial Electrician Talk area at ElectriciansForums.net
sparkyork
hey up all, had a rescent site visit to a job in leeds regarding fire alarms, he mentioned about possibility of wiring in 4 core fp to these combined sounder/detector bases. only concerns ive got is that i dont do these everyday and dont wanna confuse me self doing it this way.
am i better just going for 2 core method? points or comments appreciated:D
Test Meter - Forum Sponsors since 2007!
R
rumrunner
Its easy enough if you do a wee drawing before you start,it depends on how big the job is weather theres much difference in cost which ever way youj do it
good luck
T
tony.towa
Hi Rich,
Wiring in the combined strobe/sounder/sensor is a doddle. Just decide your colour for each fuction and away you go. If just a normal sensor or sounder are required in a specific location these can be used as well. Can save quite a bit of time on installation and a hell of a lot of P clips if you are surface mounting the cable.
Like Rum says there can be a substancial difference in cost of materials so on a smaller installation the time save may not compensate for the additional materials cost.
Tony
sparkyork
  • #5
cheers guys ill give it some thought today. have a nice day
G
Gazza D
You could also consider a 'savwire' alarm it uses one 2 core for both sounders and detection, but reverses polarity when in alarm so the sounders sound! You need special 'savwire' detector bases but you can use conventional sounders/beacons etc. If it is a small installation, that is the way I'd go.
I used to install fire alarms for Chubb, so I'm pretty good with these!
B
bongo
well better late than never......
I'am under the impression that multi circuits with a cable are not permitted?
hence 3 core common neg detection & bell circuits being in the past?
the only 4 core fp I see is for mall relays
Reply to wiring fire alarms in the Industrial Electrician Talk area at ElectriciansForums.net
Top Bottom
