Hello.
New to the forum and hoping there is help for my issue.
The receiving sensor on my garage door recently crapped out. I watched a few youtube videos and it all looked easy. In the videos there was always 1 wire in each side of the garage door. It was a matter of (1) connecting the white wire to white wire and then (2) connecting the white/black wire to the black wire and then you are done.
BUT, when I took a closer look at the wiring on my door I found something different. The left side where the sending sensor is located had a single wire - no problem. However, on the right side of the door where the receiving sensor is located there are 2 wires coming down from the ceiling. I believe one is from the unit and the other is in some way connected to an exterior electrical outlet on the exterior of the garage. I know this is so by playing with the breakers and using a non-contact testor.
I have attached a picture of the previous wiring. Attached to the black/white wire on the sensor was the black wire from one of the 2 ceiling wires. Attached to the white sensor wire were both of the red wires from the 2 wires coming down from the ceiling. There is an additional black wire from one of the ceiling wires, and from the end of it I can tell it was connected at one point.
My question is where do I connect the stray black wire? Does it belong (1) to the white sensor wire connected to the 2 red wires, (2) to the white/black sensor wire connected to the black wire, or (3) not connected to either?
Any help would be much appreciated.
