Discuss wiring help in the Auto Electrician Forum area at ElectriciansForums.net
Hello. I have a set of power folding mirrors that I'm trying to install. I have figured out there's two wires for the folding, one wire makes it fold in, one wire makes it fold out but, my problem is one wire has to be grounded in order for the other wire to work.. how would I be able to wire that for each wire to switch between negative and positive depending on how I have the two-way rocker switch positions? Hope this makes sense! Thanks for any help!
How many wires do you have ?
If you just have the two its a reverse polarity motor and you will need to wire a switch to reverse the polarity.
This might help you ;)
and all done without using wire fire nuts. crappy crimp tool though, even if it says milwalkee on the handle.
Reply to wiring help in the Auto Electrician Forum area at ElectriciansForums.net
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
Hi guys, im currently trying to start my new big block chev in a chevelle but having issues.. im a full novice on electrics so be gentle ! The...
Hello all, I have a tail light for a '12 Ducati Panigale 1199 S, that I can't get working properly. The brake light / daytime running lights...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi everyone, On my Hiace the roof LEDs are triggered by the side door that breaks the ground, not the positive wire. I want to also have an...
