Discuss Wiring Hot Tub in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
will try to flush the pumps out then that sounds good other than that there is no short in circuit, tested the sub circuit run to garage board and its fine tested individual circuit and is fine.
So what the Manufacturers name of this Hot Tub, and the model number?? Perhaps then, ...someone can then give you far better information which is based on actual data... lol!!!
What is the floor made of, which this Hot Tub stands on, Bare ground, Grass, Concrete, Paving tiles, Wooden decking etc??
Right been over to see the hot tub myself and what he told me is ******** he got of the internet and what he thought was tripping!
This is the situation with the Hot Tub:
Make: Balboa Water Group
Ran from garage consumer unit from main board in kitchen via a 50amp mcb to the garage consumer unit which also has 50amp mcb (so no discrimination) then to an isolating switch for the hot tub then to hot tub.
It is fully earthed and is protected by a 30 mA rcd, performed ramp test and ittrips at 23.0 mA.
It is ran in 10mm Armoured cable so plenty big enough.
Hot tub runs fine and starts up you can select the 2 modes of bubbles and it works fine all the lights are on it works fine, when the thermostat clicks the heating on, it shows the light and stays on for about 30 seconds then trips the Rcd.
Sounds like the heating element is on its way out. Is it new or second hand? How old is it?
Hot Tub Tripping
Read more: http://www.electriciansforums.net/e...ons/62192-wiring-hot-tub-2.html#ixzz24TiygYrk
Re: Hot Tub Tripping
oh, no, have to agree again. think i'm going to have another heart attack.
heating element , as mentioned , is toast.
and......
GFCI = ground fault circuit interupter = rcd ;-)
i've had a flick through the USA wiring regs or National Electric Code as its known , and boy is it a heavy read lol , 3 times thicker the uk 17th edition.
i lead a sheltered life.
Yep, 30 second delay till the thermo controller ( West? Eurotherm? Omron? Something like that) finished initializing itself, then the heater contactor kicks in
then the faulty heater trips the RCD.
Hard water, scale on e heater, can't dissipate the heat to the water, expands, cracks, ...
Two separate threads on the same question is going to cause confusion for those who are trying to assist you. I've merged both threads into one for you.
Reply to Wiring Hot Tub in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Replaced our old 240v hot tub with a new one, which also uses 240v for motors, heater, etc, and 120v for low amp LEDs and touch screen control...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
Hi, My hot tub keeps tripping after 12 years of use. I'm thinking it's the GFCI gone bad. Unfortunately it's a CH 2 pole 50 amp (GFTCB250) and...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
