Discuss wiring in electric oven hob and hood in the The Welcome Forum area at ElectriciansForums.net
hello
after some advice please,
i have re wired my kitchen, i have run a 6mm cable from the cu on a 40 breaker,which is where i intended to isolate it.
but on purchasing the hob oven and hood, i now know these are all separate feeds,
hob 6kw and oven 2.1kw
to solve all my issues i now intend to use a 45 amp dp with plug for the hood with 3amp plug.
is it ok for the hob and oven to go into the same 45 amp dp.
like this
https://www.NoLinkingToThis/p/briti...VCpPtCh3FywyuEAQYASABEgLfTfD_BwE&gclsrc=aw.ds
i have doubt as i am aware you can buy a dual 45dp which has separate entries for the hob and oven but it has no plug socket on it for the hood. like this
45 Amp Dual Appliance / Cooker Outlet Plate - https://www.tlc-direct.co.uk/Products/AA45DCOP.html
thanks in advance
Hi - first question would be is 40A breaker the right size? Sorry to say, but I think you need on-site help with this. How will you test and certify your new circuit?
i am a spark and my boss will be testing and certifying the work.
i have just never wired in a hob oven and hood in the same location
before.
when i originally said 40 mcb i had done math previously on different units on working out the specific calculation i have calculated its 32A mcb.
main oven 2.1 kW
four hotplates total 6 kW
The cooker control unit includes a 13 A socket outlet.
The total cooker load is 2.1 + 6.0 + (4 x 1.5) kW = 8.1 kW
Total current
8100 A
230
= 35.2A
diversity
10a + 11.1 a= 21.1a
+ 5a socket outlet = 26.1a
=32a mcb
i would appreciate if you could answer the original question.
thanks
why do people come on this forum and ask questions ,having looked at his profile .nowt showed that he his a spark .
Because that's what the forums are for.
@JAMES SLOAN , I've just deleted the new thread you started about this. Please don't post duplicate threads as it becomes confusing and somewhat irritating for people who are trying to help.
Hi - perhaps just confirm your installation method against Table 4D5 as sometimes 6mm and 40A don't work. Apologies if I'm teaching you how to suck eggs :) .
Not sure I understand the question, are you proposing plugging in the hood and terminating the hob and oven in the same terminal in the 45a dp isolator?
I think he's planning on using one of the 45A dual cooker outlet plates, and plugging the hood in.
hi thanks for responses
baddegg
yes that is correct,
if viable i would terminate oven and hob into 45a dp socket outlet,
then the hood into the socket outlet,
the radial for the kitchen is complete,and i only have a 6mm cable for the cooker hob and hood.
Reply to wiring in electric oven hob and hood in the The Welcome Forum area at ElectriciansForums.net
Hi, searched the forum but cant locate anything similar so apologies if ive missed something. Ive got a new hob to install in the kitchen...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
Hi All, An easy one for you guys I expect... I have 6mm² to kitchen, RCD protected, B32. I need to provide supply to an oven, hob (ignition...
Hi all Some advice on this would be great. Due to wire a kitchen from scratch and in a pickle over the designing of the oven and hob circuits due...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
