- Reaction score
- 0
I want to replace 4 x 12v dichromic ceiling mounted downlights, with 4 LED Downlights (similar size and fitting).
Currently, a switch supply goes to a 12v transformer. The transformer has four 12v oulets, one to each downlight.
To replace this arrangement, I have purchased 4 x Aurora M7 240v downlights. These do not require a driver and come complete with Aurora's FastFix connectors.
My question is:
Finally, can I run standard 1.5mm Twin&Earth to each light connector, or do I/should I use a particular type of cable (e.g. fire/heat resistent)?
Any help/advice would be much appreciated.
My question is:
- Should I extend my feed and provide a connector block for each light. The connector block would provide a short 'spur' to the light's connector and then run the feed on to the next connector until the end of the lighting run
- Can I use the Aurora's connector and simply loop the feed from one light to the next?
