Discuss Wiring of smart 1 gang light switch in the DIY Electrical Advice area at ElectriciansForums.net
Amr Kamel
Hi .. I bought a smart light switch from Sonoff and would like to fix it myself
The current switch has the following wiring .. L1 / COM / Neutral
The Smart Switch has the Lin / Lout / Nin
I'm not sure which wire goes where
Anyone can advise please
Thanks in advance
I cannot see a neutral conductor at your existing switch.
The Sonoff switch is unsuitable as a replacement for your current switch because it requires a Neutral at the switch which is absent. What you can see is a green/yellow wire which is the earth wire. You must not connect the N terminal of your new SONOFF switch to the green/yellow wire - it would create an electric shock risk.
You need to buy a smart switch which specifically says 'no neutral' is required - some manufacturers do make them but I don't think SONOFF do - but you could investigate further.
With a non-neutral type of switch you connect COM (old) to COM/Lin (new) and L1(old) to L1/Lout(new) - having turned all the electricity off first.
Behind the old switch it does not look like the incoming green/yellow is actually connected to the earth terminal on the old switch - it must be.
Reactions: DPG
Reply to Wiring of smart 1 gang light switch in the DIY Electrical Advice area at ElectriciansForums.net
Hi, i’ve been trying to buy a smart switch 1 gang 1 way but i opened my conventional wall switch and i only have 1 red wire(Live Old UK) 1 black...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Hi, I have a 220v House I want to change this switch to smart switch, but I am stumped, I don't have a neutral so I had to return the switch I...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
I'm trying to replace this standard 2 gand 1 way switch with a smart switch. I've put the both live wires into L in and the switched lives into...
