Discuss Wiring sensors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
N
nabba
Hi, I'm wiring lights about 20 via trunking in singles to loop in boxes , because the room is large I will need to position at least 2 or 3 sensors so either one will bring lights on ... Any advice on the wiring them pls ? I realise first off , live neutral earth to supply the sensor what do I take to the other one to incorporate it then obviously switch wire to lights its just the sensors im itchin my head at ... been that long time since did this sure it's simple just need direction
Thanks ...
Hi , thanks for getting back. Yes pir's this is the thing parellel ?? so live neutral earth from the board into first pir then would it be live neutral earth to the next one and a switch wire so that either pir switches they will all come on is this right ...? Parellel always confuses me in lighting
Thanks again .
Yes, line, neutral, earth and a switch live need to be taken between each pir.
What type of light fittings are you switching, make sure the PIRs can switch the required load.
Thanks again, I think at the moment it's going to be 600x600 square fluorescents placed into a new office refurb grid ceiling ,... Not sure what the wattage is on each one yet as drawings not arrived ...
you do need to know the load.............. to condier zs value and vd... you could break the room up say first 10m the lights come on walk a little further and the next set come on
Reply to Wiring sensors in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'm trying to wire in a 4 core capacitive sensor into a safety circuit. I have brown, blue, white and black coloured cores and it's a NO sensor...
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
I need to add shop lights to my basement. I currently have one baseboard heater that runs straight to the breaker. Its a cadet 240v/4.2amp 1000w...
This isn't really an electrical issue as such but I know you guys are pretty tech savvy and familiar with all the latest and greatest...
