Discuss Wiring size in the UK Electrical Forum area at ElectriciansForums.net
In new construction, if I make a 20amp run of say 4 outlets using 12-2 wiring, can I come off of an outlet with 14-2 wiring for my lighting? Or do I have to make a separate run of 14-2 for the lights? Sorry I'm a newbee.
your regs. are different to ours. usually we run lights on their own circuit/breaker, separate from outlets. when we do come from an outlet circuit to lights, we fuse down after the outlet to suit the smaller light cable, usually 5A.
No you can’t come off your receptacle circuit, you need to pull a separate circuit for lighting. The receptacles are on a 20 amp breaker which is good for 2000 watts and # 14 is just good for 1500 watts or 15 amp breaker
was confused there. then i realised you're referring to 120V, not 240V. DOH!.
Reply to Wiring size in the UK Electrical Forum area at ElectriciansForums.net
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
I have some 12VDC LED fixtures that I would like to put in the ceiling of our showers. My thinking is that I would run some 14/2 from the main...
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
DYI guy here with some basic knowledge of electrical craft. I am helping a buddy in his remodeled bathroom. His GFCI outlet was powered off vanity...
