Discuss Wiring/symbol help.. in the Electrical Forum area at ElectriciansForums.net
A
I want to power a small heater 2kw in my bedroom with this wireless thermostat. Because its affordable and has very fine 0.25C heat sensing switching. I'm having trouble understanding how to wire it correctly.
Question 1)
Is this able to be wired directly to the heater? its a 2kw heater so would need 10a 230V UK mains.
Question 2)
For example I can't understand what this means:
16 amp relay switching
RX Rating Max: 16 (5) A SPST
Question 3)
following this wiring diagram
to have the heater powered maybe I use the bottom image. But...
It says Max 16 (5) A . I dont know what voltage it handles/outputs, what is the (5) ???
The black triangle in circle & M in circle with two arrows. What do both these symbols mean???
Question 4)
In other words I'm confused about the (5) - maybe it means 16A 5V
And maybe the symbols are a low voltage 5V switch for a larger Volt appliance.
So basically can this be wired straight through or would it require an extra switch before the heater ???
Replies appreciated.
Thanks.
westward10
westward10
Admin
Mod
16(5)A means you can switch a 16A resistive load or 5A inductive load. What type of heater is it.
Lucien Nunes
Lucien Nunes
Mentor
Yes 16A max. resistive (heating) load or 5A max. inductive (motor or transformer) load. That is a standard way of representing relay switching capability on a control device.
And yes, lower diagram. Line feed to L and Com, N/O powers heater.
OP
A
Can you provide a link to a source of information regarding this way of noting relay switching capability? Like something I can read and learn from about this.
Reply to Wiring/symbol help.. in the Electrical Forum area at ElectriciansForums.net
Electrical News from Electricians Forums and Friends
