Discuss Wiring terminal block for induction hob in the Electrical Appliances Forum area at ElectriciansForums.net
what does it say in the instruction book .how to wire it .it should show you on the plating or the cover or .
All electrical connections should be made by a qualified electrician. • The appliance must be earthed. • Before carrying out any operation make sure that the appliance is disconnected from the power supply. • Make sure that the electrical information on the rating plate agrees with the power supply. If not, contact an electrician. • Make sure the appliance is installed correctly. Loose and incorrect electricity mains cable or plug (if applicable) can make the terminal become too hot. • Use the correct electricity mains cable. • Do not let the electricity mains cable tangle. • Make sure that a shock protection is installed. • Use the strain relief clamp on the cable
Hello...I need to rewire a terminal block for zanussi induction hob zei6840fbv
Can someone help please. ImGe attached
Welcome to the forum mate.
If you are rewiring it, how was it originally wired up?
what he says^^^^^. connection diagram will be in the manual. having looked that up.it states that the hob comes with cable already attached, an electrician with a test meter should be able to identify which terminal is which.
L to teminal #1 linked to #2. N could be #4 or #5. that's an educated guess. ( and pirate can do the earth.:p:p:p.).
Reply to Wiring terminal block for induction hob in the Electrical Appliances Forum area at ElectriciansForums.net
hi looking to install a new induction hob to current wiring . the wiring i have is thick white probably about 15mm wide and is hard wired into...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
We have an install where the client has supplied an induction/gas hob combination unit. We have a 6mm cable supplying the hob, the induction part...
Hello, Looking at changing out my gas hob for the PIV851FB1E Bosch Induction Hob. The Induction hob is 7400W and by my calculations this would...
Hi all, I am about to fit a light fitting and wanted some advice whether I should just connect the light cables into the correct terminal blocks...
