- Reaction score
- 6
Am sorting out some of the electrical defects for the landlord of my local pub, and would welcome advice on a solution.
One of the more minor issues for which improvement was recommended regards the spur which supplies the fire alarm - presently it is wired in twin and earth and obviously this would be better done in FP200 - the only issue I've got is that only a metre of cable is required between the spur and the DB, and all of the wholesalers I have tried will only supply in 100m reels.
Aside from the metre of cable I need, I am unlikely to ever use FP200 again in the foreseeable future, so it would mean taking a massive hit on the job, nor can I justify passing on the cost a full reel (approx. £60 - £70) to my customer. I have asked the wholesalers if there is any alternative cable they can cut to order and the short answer is no.
Once solution I have pondered is as follows - the fire alarm panel itself is mounted at the side of the DB, so it would be possible to relocate the spur above the board and to the side of the FA and bush it side and bottom, meaning all the cable is in effect, contained. Is it acceptable to wire a fire alarm this way, or does it have to be wired in fire-proof cable regardless of the installation method?
Obviously, being a Code C3 on the report I could just leave it, but it would be a reasonably quick job to resolve and I would like to rectify as much as I can especially as my client has accepted he finally he has no choice to spend some money on improvements, seeing as he wants to sell so he can retire to his boat on the Med!
