Discuss Wiring under cladding in the UK Electrical Forum area at ElectriciansForums.net
JustYatez
I a few years ago I did some cladding to my house. I'm trying to run some ethernet cable to my room as there is already a whole in my wall (must of been made by past owners) but it's covered by the cladding. I don't want to drill through the adding instead run the cable under it and then put through the bug mesh. (The cladding is on the top half of my house) is it possible and what is the easiest way of doing it
Reply to Wiring under cladding in the UK Electrical Forum area at ElectriciansForums.net
Hello, I am an enthusiast amateur undertaking wiring of two outbuilding under a building notice. I am soon to be subject to a first fix inspection...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Doing some work in a commercial restaurant/kitchen the builders had already boarded and plastered the walls meaning my only viable route is to use...
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
