jadelong1076
- Reaction score
- 0
Hi All!! I'm new to the forum and seeking some specific advice.
Background:While I do understand and have some limited experience with running wire, wiring outlets and panel hookups in basic residential wiring, I need advice on specific challenge. I live in a rental that has garage wall outlets on 14 AWG with a 120V/15A breaker (Lights and wall outlets on separate breakers).
I am in the process of setting up a woodworking shop in the garage. I want to use a 2HP Hybrid tablesaw that is prewired to 230V but can be wired to 115V with kit (that includes a 20A breaker..inside the saw panel?). Saw has the following criteria...
Power requirements: 115V or 230V, Single-Phase, 60Hz
Full-Load current rating: 16A at 115V, 8A at 230V
Minimum circuit size: 20A at 115V, 15A at 230V
Powercord gauge: 14 AWG
Question: I am in a rental and cannot change/upgrade the internal wiring to 12AWG in order to just "Change the breaker to 20A". I do have room for additional breakers in my panel. Can I insert 15A /230V breaker (double pole 15A??) and just move the wires from the 15A/115V directly to the 15A / 230V wiring the white wire to top and black to bottom poles? As I understand it, this will only pull 8A and thus allow me to keep using the existing14AWG.
[automerge]1573515217[/automerge]
