Discuss Wish me luck in the UK Electrical Forum area at ElectriciansForums.net
Pete999
Going Coventry on Friday to see a spinal surgeon about my knackered back, so good luck wishes will be gladly recieved
Good luck and best wishes from me, hope it works out well and they get your back feeling better.
All the very best to you mate, If the Docs are anything like we have at the Freeman Hospital in Newcastle you will be just fine.:smile:
Good luck and I hope they can patch you up owt lad because your movie career depends upon it!:wink:
best of luck, pete. hope it goes well for you. if to take a video, then you can fix my back on the cheap.
just watch them nurses when you're lying face down on the bed. likely get a daffodil stuck in your arse.
You will probably bump into my father in law as im sure he is going about is back too then, he needs another operation on his spinal cord or something as hes knackered and cant really walk.
I hope your meeting with them goes to plan!
Pete. Which surgeon you seeing. Had my back done at University Hospital Coventry.
Mr Shad was the surgeon. If you want to know anything just pm me.
Neil
Reply to Wish me luck in the UK Electrical Forum area at ElectriciansForums.net
I spend a lot of time renovating vintage broadcast radios, military radio and test equipment. At present adding panels to our off grid...
If not, would you take one one? for the second time and against my better wishes we have got one but my business partner always seems to have a...
I'm unsure if I should be an electrician or maybe another trade is better. I have basically completed my first year of a foundation in...
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
I'm converting my garage and have about 15m of skirting being installed which has a groove in it I wish to install a (dotless) RGB led light strip...
