Discuss working at height. in the UK Electrical Forum area at ElectriciansForums.net
Hello all.
just a rant really, survey a job at an old chapel, rewiring due to ---- poor ir, old vr & splitting power & light to a replacement rcbo sub main agreed, quote agreed & massively highlighted on bottom that scaffold tower at 5-6 meters required but not costed as foot note & acknowledged, accepted at the time. day before on site ring to confirm all to be told that they have decided we do not need a tower at that height, they have a triple ladder that will do, always has & we can use that, it will be ok as thats what everyone else has done. we have to get access to loft / attic space as well as access to 3 separate battens 3.5 meters of the deck.
Is it me or am i being overcautious?
Thoughts?
What others do is irrelevant really. If your risk assessment highlighted the need for a tower scaffold then so be it, no one has any right to challenge that especially a customer who only sees the cost.
I could understand them asking you if you can use a ladder instead but point blank telling you that you're going to use one isn't acceptable.
Agreed ^
We rewired a church last year mostly off of extension ladders and it is bloody hard work. Lots of climbing up and down as there is only so much you can carry. A lot of time wasted securing and unsecuring the ladder as well. Ended up taking a bucket with everything needed at that point which saved a lot of time. Tower would have been difficult and time consuming to erect due to all the changes in levels and fixed furniture though, the legs would be very long and wobbly with the cross bars having to be so high up. We could have completed the work in a fraction of the time if a full scaffolding had been put up from one end to the other in all positions and we could just walk along.
I use a mix of access equipment, sometimes ladders if simple job, sometimes scaffold if job more complex, sometimes scissor if heavy work and i need to move around. As i am the only one who knows what i need to do, it would be quite odd for a client to tell ME what would or would not be necessary. Its purely up to you, clients know jack about our profession
Working height of 12ft for three battens and attic entry doesn't seem too excessive for ladders. Why a 5-6m scaffold? If you're talking working at that height it's a different proposition. You know what you need so insist on it.
Your health and safety comes first. The client isn't going to compensate you if an accident happens and they have no idea how awkward and potentially dangerous it can be to try and work off a ladder especially if you end up using both hands or over reach. Scaffold tower or MEWP is always my preference for working at height.
It’s a church. God will keep you safe.
Bo**ocks
have you seen this magic ladder? I bet it’s made of wood and has 3 very important rungs missing.
insist on your scaffold. But it should have been in your costings from the start, although customer should have read more carefully.
My advice go to the government HSE web site and follow the guide lines and if required show these to your customer
Seen things in black & white might get them to see your point of view. At the same time give you a clear understanding of what is expected from the HSE.
Even working at 4m changing lights in suspended ceilings I use a tower. The cost is not that much and the saving in time offsets that cost. The weight of a triple ladder alone (imo) is a danger in itself. I see on site guys using triple ladders to do roofs instead of scaffold looks very dangerous to me. But my WAHR RAMS would not allow ladder access in a scenario like yours. As you can see from my photo I even need a tower for that. But it is my own tower.
At the end of the day it's your own safety you are gambling with. If you want to take the risk just to save the client a few quid then that's your choice. Its up to you to assess what the risk is.
From a legal perspective, if you follow the HSE guidelines and there is an accident then at least you have covered your back .
HSE working over 5 meters on a ladder is not excepable then saffolls would have to be used .so if you fall no kings horses will put back togehter only the local AE love ,humpty dumpty
Personally i would go with your own risk assessment and that should be based upon location, height, access available, time that you need to be up there and personal safety.
Good Luck
Reply to working at height. in the UK Electrical Forum area at ElectriciansForums.net
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
E
this man was relatively unknown to me till today, from what ive seen he seems a bit on the mental side i know there is folk that ---- and moan...
S
Hi All For sale is my scaffold which consists of; 2 platforms with trap doors 1 base section 4 wheels (adjustable) 4 long outriggers 4 silver...
seprim
S
