Discuss Working in a school in the UK Electrical Forum area at ElectriciansForums.net
Hi,
ive managed to secure one work for a school, nothing big, just a number of accessory changes etc and a couple of additional sockets.
ill be up front, I've never done any work in a school.
is there anything I should know about? Work will be done out of school hours.
my main query i suppose is that they want a couple of additional sockets, that's fine, but will need to totally power down the related board as to be able to test it properly, does anyone have any pointers as to bed method or what to suggest to them?
ive not yet investigated as to where the circuit is fed from, but just looking for any advise really on the whole school thing.
thanks
Hi,
thanks
You will need all risks insurance to keep the county council happy to start, that is usually 2-3k, when you quote for work ask the school before submitting the costs whether you need to allow for out of hours work, school boy stuff Really.
Sounds like a classy job to me :)
Think I'll get my coat as well....
**edit** Your like was for that schoolboy stuff comment MDJ ;)
Hi,
thanks
Best not say that when you are on the school premises! :21:
Ive just done an eicr on a school, out of hours for obvious reasons and replaced a load of light fittings. In my tender had copies of generic risk assessment, method statement, PL and PI insurance certificates, NIC registration certificate, ECA registration certificate, etc
Don't forget you will also need to do an enhanced CRB check working in a school
Unless the local authority don't ask for one. I worked for years on schools with no checks. One day they decided they had been remiss in their duties and we all had to get them.
You can get an ECS photo card that proves your enhanced CRB status which is what I ended up with.
What is all risks insurance? I've got PL at ÂŁ5m and PI, I'm only swapping a few fittings and adding two additional sockets so not going to splash out on any other insurance, it's only worth ÂŁ100 anyway.
ive not got a CRB, the have not asked and I've not said.. I should perhaps look at getting one, but as its out of hours I can't see the need.
Not if you're working outside school hours. I have worked in nearly 20 schools (including during school hours) and have never been asked for any sort of CRB for school work, let alone enhanced.
Maintainence jobs in schools are great fun, sorting through years of bodgery perpetrated by the 'approved contractors' and layered on top of a 1960's steel conduit install. And all in that magic hour between the caretaker unlocking the door and the first child arriving.
I work in a school currently. You shouldn't be asked for crb, and as a school it's up to us who we use for installs. For sockets etc we use a local well priced company, for bigger jobs (like db issues) we usually get the council team in. We've had a full IT suite of power installed by a local company without issue (ie council pencil pushers on our case). As for install methods, that again is our perogative. The older installs are steel conduit but recently we've opted for plastic trunking in a bid to make the job cheaper.
Reply to Working in a school in the UK Electrical Forum area at ElectriciansForums.net
This drives me round the twist, the client tells you what they want, kind of. you do the work the way the client asks you to and then when its all...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Afternoon all, and apologies if this has been covered elsewhere, but a search didn't bring anything up. Just a quick heads up to anyone...
