Discuss working in ireland in the Ireland area at ElectriciansForums.net
A
andrewcann
going to do some work in ireland for a mates brother and have a few questions.
is there a diffrent colour code out there or is it the same as over here and haveing a new meter fited but there said that they need the electican to paper work first but didnt now if i was ok to sign it off i have 2360 part 1 and 2 17th edition and 2391 any help would be great full
Mate
I believe if your going to the South you need to be registered they have 2 main bodies the big one called RECI. The regs are very similiar the colours are the same. Worth dropping RECI an email for advice.
I hope this is helpful
If you are working in the south of ireland then you can not go by BS 7671 you have to comply to the ETCI wiring regs although similar not the same.
The supply authority is the ESB and before they will energise any supply for you must hand in certificates of dead testing to them. Certificates must be issued by either a RECI approved contractor or an ECSSA approved contractor.
When the installation has been energised the live testing must be completed.
Another thing you must do in south of ireland is neutralise your supply, basically this means that you make the supply into a TNCS system by linking the main neutral to the met and installing an earth electrode connected to the met.
Reply to working in ireland in the Ireland area at ElectriciansForums.net
Good afternoon my name is Steve and I’m new to this forum. I have a dilemma I’m a qualified electrician currently holding Approved electrician JIB...
Hi hope someone can help , I did my 2360 parts 1&2 between 1998 & 2001 I have the following part 1 units Electrical installation theory part 1...
Hi everyone, A quick background to me and my question. I have been working for a commercial catering equipment engineering company for about 10...
Hi guys I'm a recently qualified C&G Level 2. I have my 18th edition on the way in the next few weeks. I have a CCNSG AND IPAF 3a/b card, happy...
Good evening. Any advice what to do in this situaltion would be very much appreciated. I was called by a landloard who lives in Denver . She...
5K
