Discuss Working out how old an installation is in the Canada area at ElectriciansForums.net
A
AlanDavies
Does anyone out there know, when the major material changes in Uk electrical installations took place, i.e:
when lead cable stopped being used
when rubber cable stopped being used
when the earth colour changed from solid green to green and yellow
insulation on live and neutral pins of plug tops
flex colours changed from red and black to brown and blue
stranded earth in T&E cables
Cheers
Alan.
Cheers
Alan.
Earth cable colour change 1971 both colours in use but green/yellow only from 1977
Flex colour change 1971
Rubber (vir/trs) cable stopped being used in the late 50's early 60's
Lead cables used in the 1930's stopped being used from 1948 (told this by an old boy who was a sparks during the war)
use of a gas,water or other service pipe as the main earth
It has never been permitted for gas pipes and has not been permitted for other service pipes since 1966.
voltage-operated earth leakage circuit breakers
two basic types of earth leakage circuit breakers used to be recognised by the wiring regulations: the current operated type (RCD) and the voltage operated type.
the voltage operated type ceased to be recognised in 1981.
absence of c.p.c. in lighting circuits.
All lighting circuits installed since 1966 ( with the exception of certain extra-low voltage circuits) have been required to include a c.p.c.
double-pole fusing
In many installations put in up to the 1950s, the circuits have a fuse in the neutral conductor as well as in the phase conductor. This is potentially dangerous for ac installations, and ceased to be permitted by the wiring regulations in about 1955.
non-13A socket outlets
the installation of socket outlets other than the current standard 13A square pinned type was common prior to the early 1950s. These outlets accept non-fused plugs( some with an earth pin and some without),generally having round pins.
concealed cables outside the safe zones
untill the latter part of the 1980s the wiring regulations did not contain any specific requirements for the positioning of cables concealed in walls or partitions.
Cables of imperial (non-metric) sizes
up until the beginning of the 1970s, cables could still be purchased having imperial, rather than metric, sized conductors.
Accessories on wooden mounting blocks
It was commonplace up to the mid- 1960s for accessories such as socket outlets light switches and ceiling roses to be fixed to wooden mounting blocks.
Reply to Working out how old an installation is in the Canada area at ElectriciansForums.net
Wouldn't normally note this as an observation on a report but feel I need to. The way the building has been wired is all circuits on L1 have been...
Hi, I'm trying to rewire an old plug. I've rewired a few in my time, but all have been with the post-2006 wire colours. I have this old welder...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
I've fitted some led lights with power supply and mi light controller, they were working fine and all colours could be seen, then for some reason...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
