Discuss Would this need Part P? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
PVKitsDirect
A system to control an immersion heater from excess generated PV power.
The control unit uses a clamp round the mains at the meter and wirelessly turns on the immersion element. The existing immersion isolator is replaced with a new fascia with the wireless gubbins inside.
So, no new wiring is required.
Would it need Part P?
Thanks - the only thing it might need is a 13A supply near the meter to power the controller.
That obviously would require Part P - correct?
If you are just adding a socket or an FCU to an existing circuit (not in a kitchen/bathroom/outside etc) then you would not need to notify the change under part P, it would just need the usual electrical installation inspection testing and certification.
Reply to Would this need Part P? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Firstly, thank you for taking the time to read this. I am not trained in electrics whatsoever, I am a just a home owner looking for advice. I...
Hi all We've had some works done in our kitchen which has involved fitting a new cooker circuit, installing some downlights to replace ceiling...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Hi, Have normal fused immersion heater switch. I would like to add a smart wifi switch to it so when my Solar is producing over 3k spare, going...
