Discuss Would you consider these accessorries too close to the hob? in the UK Electrical Forum area at ElectriciansForums.net
Hi, i was given measurements from the tenant and they happemed to be slighty wrong. Now iv already ran cables and the plasterer has already done his job. Looking at the pictures the tenant sent me, the accessorries seem a little close to the hob. What can be done now? Do you think its ok as it is? Is ther e like a fire rated accessory i can purchase or is the only option to move the accessorries? Please see attached pics. Thank you all in advance
can you move the single box to the other side of the double box whilst keeping cables in prescribed zones?
Not sure what the single box is for (cooker hood, hob ignition?), but way too close, especially if you want to switch it off while the chip pan is on fire! Even the sockets are a bit too close.
Hi,Looks closer than the recommended 100mm.....not in reg bible,but bound to cause an argument....
thought it was 150mm. bloody metric confusion.. 6 bloody inches can be visualised. 150mm i need to use a dual standard tape measurer to compare.
I've had to move existing accessories before this close to a hob, before the gas fitter would install a new hob. Not sure what their rules are.
usually in conflict with ours. e.g. insisting on bonding to the external gas meter when it is 20 ft. from where the service enters the building.
OR......a hinged lid,over the hob,with a micro-switch,interlocking a contactor,isolating supply to that socket....
I may be over thinking it,but i'm out in the rain shortly,wrestling the floppy,broken gear stick,off a small tractor,so this keeps me dry and cheerful ...
it's always raining in munchester. what;s new?
What's new? ...well...the worlds sicker,sadder and sillier...but,with a good sense of humour and some grit,it's all possible.
Never had a bigger variety of jobs...not all resulting in golden eggs,but,all gratefully remunerated.
I've just got engineering to deal with,me sisters have the soggy end of the stick...one's a copper,the other in NHS...harder things to repair,people (would insert a smiley,here,but Qanon has given them to Satan,as a gift)
I was looking into this recently, and most sites seems to agree that for the Gas regulations, it's 150mm to each side of a gas hob (up to 400mm). Though when I tried to track the official source down I couldn't find it - I suspect it's in their BS book, which I'm certainly not buying to confirm.
It's unclear to me whether an all metal switch that was not 'flammable' would comply in that zone - but then most metal switches have some plastic in them anyway.
Reply to Would you consider these accessorries too close to the hob? in the UK Electrical Forum area at ElectriciansForums.net
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
I commissioned an EICR to be done on a property that is in Wales as this is now a requirement in order to let on any new tenancies after 1st...
So I am a fully qualified spark with my own company, however I also have a few properties I rent out. One of my tenants asked if they can have an...
10K
