Hi Everyone,
Thanks for all your input for other posts.
Writing out my certificate for a job and was wondering how best to approach it.
Previous sparky made provisions for the garage wiring by putting in a small distribution CU direct from henley block and a wire to the then proposed garage area. This is all on TN-CS
Garage has now been built and I have taken his feed and wired up garage with a CU in the garage. I have terminated the earth from TN-CS and installed TT.
I tested at CU in house up to my CU in garage, and then did all my tests again for final circuits at CU in garage.
When it comes to the cert do I need to do two completely separate ones or just the one concerning final circuits or can I somehow combine both.
Many thanks.
Oli
Many thanks.
Oli
