Discuss WTF is this or I don’t recognise this unit in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi folks, some identification help required.
Customer has helpfully lost the alarm but has retained the base plate.
She thinks this was interlinked with some Kidde Firex smoke and heat alarms still in situ elsewhere in the house.
I’ve not got wander lead out yet to see if the interlink exists.
Anyone recognise the baseplate/ connector? Or have an idea why there are two neutrals (maybe)?
Any help much appreciated.
If you remove those two screws you will see the mains terminal block where the cables connect. I cannot remember how those four wires connect to it.
Reply to WTF is this or I don’t recognise this unit in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I installed some aico smoke detectors about a year ago. They are interlinked with radio bases. The customer has just discovered that when she...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
Having a bit of a mare at the moment with a small 2 story HMO (6 single rooms with shared kitchen) which was fitted relatively recently (2016 or...
Hi all I have a small problem with a job im doing, 2 first floor flats above a shop with separate landlords area for the 2x flats which is a...
Hi I don’t know how resolve this so any helpful advice would be greatly appreciated. I have no electrical knowledge. I will try to be as clear...
11K
