Discuss Wylex NHTPSH100, What fuse type? in the UK Electrical Forum area at ElectriciansForums.net
GBDamo
Can't shut off this switch fuse to see what type of fuse is in it. Needed for EIC.
It says 100A but not the type, I'm guessing its a BS88 but would like to know if this is all they take or if they vary, in which case it'll have to be a scheduled shut down.
Internet doesn't really give any clues so I'm drawing on the expertise on here.
You cannot say for certainty what is in there aside from a British Standard maybe unless you can see it.
They will be BS88 and they normally come with fitted links to the size of switch so 100A. The problem is they are likely to be A4 size and off the top of my head that size ranges from 100 to 200A so you can take nothing for granted.
Edit, just read the pdf Wilko has just put up and it appears my head still works:D
Yep, Wilko's link above confirms everything you say, not that I doubt you.
Will throw it and have a look on next visit.
Cheers.
Reply to Wylex NHTPSH100, What fuse type? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
I came across this fuse twice. Could someone here let me know what type of fuse this is.? I need to fill EIC.
This is quite lengthy so get comfy... I had a bizarre call out relating to a job I attended about five years ago. The situation was they were...
Here's a Sunday puzzler for you all..... I've a large rental stock of properly made up mains adaptors for use in Europe and elsewhere - so...
