Discuss Wylex Old Style HRC 60 amp fuses? in the UK Electrical Forum area at ElectriciansForums.net
Apologies for newbie question- I'm only an occasional sparky and get stumped by these things from time to time- What's the best way to get hold of these old Wylex fuses? I presume they're not made any more like this? Hope this picture comes over OK....
@OP. is it a 60A you want, or some other value? i've got a few.
What's the reason for replacing....has it blown? If so, how do you know, is there no supply? Does it need downgrading? Is it for a new circuit?.......
The whole thing as pictured, with whatever wire / copper it needs inside it make it do its job. Thanks Gavin- will check these people out.
The fact that you don't know what's inside the fuse carrier strengthens my view that a 'part time sparky' is a fallacy.
Edit: What I mean to say is that you are either a sparky or you are not. Respectfully, you a clearly the latter.
It's simply absent as the circuit was taken out while a flat was being renovated, and someone didn't keep it in a safe place. Just want to replace it. Nothing blown etc. It's the main fuse post Key Meter into the flat, alongside 6 identical old fuse boxes. I know I could run a lower rated fuse here, but thought why not stick the same back in it as was in it before.
Reply to Wylex Old Style HRC 60 amp fuses? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
I'm having an extension built and the builder leading the project has said that the electrician will be over in about 4-6 weeks to start his works...
Hi all, For clarity, I'm not a qualified electrician, but have a reasonable amount of experience as I've done plenty of wiring (signed off by a...
About 15 years ago, after having had a modern consumer unit fitted, and prompted by our electrician, I asked my then energy supplier (Tonik) if...
5K
