C
cameronj
Hello
I am to install a Xpelair GXC6 fan through a wall with the WK6/8 wall kit. The hole required is 203mm in diameter. Given that the width dimension of the fan is only 210 mm this only leaves 3.5mm on either side.
If anyone has installed the above could you please tell me if this is correct. I am getting the hole cored so quite important.
Thank you
cameron
Thank you
cameron
