Discuss You know what it's like in the UK Electrical Forum area at ElectriciansForums.net
Pete999
As the title suggests you know what it's like when you are bored and start thinking of times past.
A 230 V supply feeding an isolation Transformer 230V /23OV feeding some equipment, on the Secondary side of the TX a DP RCD is fitted, question if the RCD sees a fault on the equipment will it trip on an Earth fault? the Secondary output is center tapped 110V each side of the Earth.
Yeah well when your memory aint working that well, go with what comes to mind first before you forget it.
I'll go with that...…. then again, I can probably remember stand out times 4 decades ago better than 4 months back.......but 4 seconds???? Sounds like it's when you nip out to the wholesalers, arrive and then can't remember what you've come for:rolleyes:
An RCD will work downstream of a transformer provided one point on the secondary is earth-referenced (and connected to the load CPC if present.) If that point is also used as a neutral, then the N-E link must be between the transformer and the RCD. E.g. on a 230V TN system, the earth-referenced point is also the neutral; the N goes through the RCD but the CPC does not. On a 55-0-55 site supply, the centre-tap is not used as a neutral but it is still earth-referenced so the RCD will react to a fault on either line.
On non-standard voltages between the outers, the RCD test button may not behave correctly as it will pass the wrong test current.
Reply to You know what it's like in the UK Electrical Forum area at ElectriciansForums.net
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Hi Basically I have visited a youtube link of another electrician and he is talking about how many electricians find RCD fault very hard to...
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
