- Reaction score
- 17,081
As the title suggests you know what it's like when you are bored and start thinking of times past.
A 230 V supply feeding an isolation Transformer 230V /23OV feeding some equipment, on the Secondary side of the TX a DP RCD is fitted, question if the RCD sees a fault on the equipment will it trip on an Earth fault? the Secondary output is center tapped 110V each side of the Earth.
